Help with a box for 2 sa12
Jb19
Fb = 34.5 Hz
Vb = 3.8 ft^3
External Height = 14.5 in
External Width = 35 in
External Depth = 22 in
Port Width = 4 1/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2x Front = 15 3/8 x 13
2x Front Internal = 13 7/8 x 13
Back = 35 x 13
Left & Right Sides: 20 1/2 x 13
Top & Bottom = 35 x 22
Shared Port Internal Assembly Parts:
2 x Front to Back = 18 3/8 x 13
2 x Extension = 1 11/16 x 13
Assembly guide (generic dimensions):
Important notes:
- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.
Hey Joe x,  you recommend this enclosure a few years ago. I was hoping you could help me out. I have the same subs (sa 12s d4) on an audio pipe 1800. I'm on stock electrical though, so I doubt I'm getting more than 500 Watts per sub. I feel like this enclosure would work well, but I have more height than depth. So I was wondering if you could come up with something 22h*35w*14.5d still tuned to about 34hz. Ideally I want the subs down port back with the sides extend to give me about two inches of clearance on the bottom It could be a little taller or deeper since I'm going to be underpowering them so 4cu ft would be better I think. I obviously don't really know so any and all in put would be greatly appreciated. Thanks in advance for any help or insight.
Yeah that would be awesome.  I'm sorry I directed that towards Joe x because he came up with the original thing but I'm not opposed to anyone else's opinion, advice or design. Just hopefully I can get get something today because I was hoping to build it this weekend.
23 hours ago, Jb19 said:
Looks like it won't be a weekend project after all. Still, I'd appreciate any help
I don't know how I forgot about this one man. My bad about that fa real. I actually have to sit down and go over a couple designs. I'll try to have some numbers for you tonight.
Cool man thank you! So I just follow the design with your dimensions, making my port 12.25 towards the back and 13.75 to the sides?  And I get the 45s but is the triangle at the back of the port necessary?
1.5 off the back wall split in both directions so... 13". Then 9.25 to the left side and right side. Physical Port length is 22.25. as far as the piece in the back... Up to you. Seems redundant imo. Nothing wrong with that tho in this hobby
I'm all for redundancy, if I can get it right I'll probably throw it in. You had the port listed as 20 tall x3 wide x26 long , but it only needs to be 22.25 long?
  • Who's Online   0 Members, 0 Anonymous, 1462 Guests (See full list)
