Box enclosure
Hervan James
Should be pretty simple but I need some more infos, I believe there's both hatch and trunk versions of that, which is it? Then max dims for  a box and model (exact) of the sub, that model usually starts with a "TS-W" either on the driver or the box, that should be enough.
So here is a suggestion,  power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 2 1/4", figure is just an assembly guide:
NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside.
  • Who's Online   0 Members, 0 Anonymous, 1015 Guests (See full list)
