Hervan James Posted October 15, 2018 Report Share Posted October 15, 2018 Need help in building a box for one single pioneer sub 2000 watts want it between 28hz to 34hz any help thanks Link to comment Share on other sites More sharing options...
Joe X Posted October 15, 2018 Report Share Posted October 15, 2018 What's the vehicle and amp? Link to comment Share on other sites More sharing options...
Hervan James Posted October 16, 2018 Author Report Share Posted October 16, 2018 Putting it in a nissan Tiida and I have a 1000 rms Rockford Link to comment Share on other sites More sharing options...
Joe X Posted October 16, 2018 Report Share Posted October 16, 2018 Should be pretty simple but I need some more infos, I believe there's both hatch and trunk versions of that, which is it? Then max dims for a box and model (exact) of the sub, that model usually starts with a "TS-W" either on the driver or the box, that should be enough. Link to comment Share on other sites More sharing options...
Hervan James Posted October 16, 2018 Author Report Share Posted October 16, 2018 The speaker is a TS-W3003D4 and the car is a nissan Tiida sedan not a hatch back and the trunk is big enough I've fitted a 36" dim in the trunk so anything that size and smaller would be good Link to comment Share on other sites More sharing options...
Joe X Posted October 17, 2018 Report Share Posted October 17, 2018 So here is a suggestion, power: to sub rated, amp subsonic filter to 28Hz, minimum port clearance 2 1/4", figure is just an assembly guide: NOTE: If building outside you need to build a cardboard dummy box to test fit in it's way inside. Link to comment Share on other sites More sharing options...
Hervan James Posted October 17, 2018 Author Report Share Posted October 17, 2018 Thank you so much going to work on it this weekend Link to comment Share on other sites More sharing options...
