camino_1to3 Posted May 4, 2008 Report Posted May 4, 2008 How do i determine what size amp fuse to use depending on my system .. i'm gonna be running about 1350 watts.. yellowtop battery Team T3 Audio Team Sundown Audio Team O.B.M Operation Beast Mode "Believe half of what you see and none of what you hear" wigglez that was a bit over the top, i dont want to invison dw giving any young lady a "cream pie" let alone "throat babies".
Guest Posted May 4, 2008 Report Posted May 4, 2008 just count the size of the fuses on your amp (40a x 2 = an 80a fuse) go maybe like 10amps higher than your amp's fuses add up together
camino_1to3 Posted May 4, 2008 Author Report Posted May 4, 2008 just count the size of the fuses on your amp (40a x 2 = an 80a fuse) go maybe like 10amps higher than your amp's fuses add up together alright, mines a 40A x 3 .. so maybe run a multi fused block with 4 40 AGU? would the little extra hurt anything? Team T3 Audio Team Sundown Audio Team O.B.M Operation Beast Mode "Believe half of what you see and none of what you hear" wigglez that was a bit over the top, i dont want to invison dw giving any young lady a "cream pie" let alone "throat babies".
