BustedSub Posted March 18, 2019 Report Posted March 18, 2019 Hello all and thanks for the help. So im preparing to build a new box it is 5 cu ft tuned to 34hz with two 12s in it. I am having trouble finding my port length im using straight 6" pvc pipe, on one program it says i need 6.65" and another it says i need 8.. So any help would be great! EDIT: Also says port area only 28.26?
Triticum Agricolam Posted March 18, 2019 Report Posted March 18, 2019 A 6" port is 28.26 sq in. How much power are you running? A single 6" port is most likely not going to be enough port area. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
BustedSub Posted March 18, 2019 Author Report Posted March 18, 2019 I'll just be running about 2k watts for awhile, and that's what i was thinking with the port area but i read that it should be much higher. Then i got confused lol.
Triticum Agricolam Posted March 19, 2019 Report Posted March 19, 2019 1 hour ago, BustedSub said: I'll just be running about 2k watts for awhile, and that's what i was thinking with the port area but i read that it should be much higher. Then i got confused lol. OK, yeah on 2k you need two 6" ports. Here is a link to my port area calculator: https://goo.gl/STAv4p With two 6" ports, to tune a 5 cu ft box to 34 Hz they are both going to need to be about 22" long. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
