Kylemoney01 Posted May 6, 2019 Report Share Posted May 6, 2019 What’s up guys first time on the forum and am looking for input on a box for my single sa12 also running there 1000v2 at 1ohm. Been looking around and can’t come to a conclusion. I would like to build it if possible but have no clue how that software works. Any help would be appreciated. Thanks guys Link to comment Share on other sites More sharing options...
SnowDrifter Posted May 6, 2019 Report Share Posted May 6, 2019 Welcome to the forums! Couple questions for you: - What are your listening goals / what sort of music do you listen to? - What dimensions to you have available to work with? - Any special notes? e.g. going in a trunk with items rolling around, SUV, under seats, etc ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Kylemoney01 Posted May 6, 2019 Author Report Share Posted May 6, 2019 27 minutes ago, SnowDrifter said: Welcome to the forums! Couple questions for you: - What are your listening goals / what sort of music do you listen to? - What dimensions to you have available to work with? - Any special notes? e.g. going in a trunk with items rolling around, SUV, under seats, etc Thank you! I would like the system to hit hard and be clean and I mostly rap/pop usually bass heavy stuff. The car is a 2016 ve Jetta. I can get the exact measurements if need be but completely empty trunk Link to comment Share on other sites More sharing options...
Kylemoney01 Posted May 7, 2019 Author Report Share Posted May 7, 2019 So I pretty much figured out that I need a 2ft3 vented box tuned to 35hz. Does anyone have a good design for one? Or know where I can get one? Link to comment Share on other sites More sharing options...
schwol Posted May 7, 2019 Report Share Posted May 7, 2019 I'm shopping for a new sub and Sundown has designs on their website https://sundownaudio.com/index.php/subwoofers/sa-series Link to comment Share on other sites More sharing options...
Kylemoney01 Posted May 7, 2019 Author Report Share Posted May 7, 2019 1 hour ago, schwol said: I'm shopping for a new sub and Sundown has designs on their website https://sundownaudio.com/index.php/subwoofers/sa-series They do but the sketchup link doesn’t work I need the box print measurements and I can’t find those Link to comment Share on other sites More sharing options...
schwol Posted May 7, 2019 Report Share Posted May 7, 2019 1 hour ago, Kylemoney01 said: They do but the sketchup link doesn’t work I need the box print measurements and I can’t find those This is a screenshot of that design in SketchUp Link to comment Share on other sites More sharing options...
Kylemoney01 Posted May 7, 2019 Author Report Share Posted May 7, 2019 25 minutes ago, schwol said: This is a screenshot of that design in SketchUp Perfect! That’s what I was looking for thank you. And that’s a 2ft3 tuned to 35hz? Does it say? Link to comment Share on other sites More sharing options...
schwol Posted May 7, 2019 Report Share Posted May 7, 2019 1 hour ago, Kylemoney01 said: Perfect! That’s what I was looking for thank you. And that’s a 2ft3 tuned to 35hz? Does it say? I can't say for sure but I'd assume it's pretty ideal for the sub, but it doesn't give specs Link to comment Share on other sites More sharing options...
Kylemoney01 Posted May 7, 2019 Author Report Share Posted May 7, 2019 1 hour ago, schwol said: I can't say for sure but I'd assume it's pretty ideal for the sub, but it doesn't give specs No problem. Thanks again Link to comment Share on other sites More sharing options...
