John1997 Posted July 8, 2019 Report Posted July 8, 2019 Need help designing box for 2 sundown zv5 12 . 32.5 wide 15 tall 32.5 deep max like to have it aero ported and subwoofers firing forward . Going in Chrysler 300 . Will be powered by sundown 3k at .5 ohm to I get another 3 k . Iny help with design will be appreciated thank you
Triticum Agricolam Posted July 8, 2019 Report Posted July 8, 2019 A 10" aeroport would be the minimum I'd suggest based on the amount of power you are going to be running. The problem is you will have a very hard time fitting one long enough inside your enclosure without having some of the port sticking out of the box. If you are OK, with having the port sticking out of the box you can make it work. Otherwise I'd suggest a slot port with 100 sq in of port area. "Nothing prevents people from knowing the truth more than the belief they already know it.""Making bass is easy, making music is the hard part."Builds:
