2 Torres Box calculators, same input, different results/
So, I have the 2010 version and the 2011 V1.1. Which version is most accurate?
Input specs
H=14 W=18 D=27.75 .  Both of the cut sheets match.
Port  H=12.5 W=1.75 L=18
Misc .20 displacement , # of extra Baffles 1, Baffle thickness 0.75, port thickness 0.75, common walls 3
2011 2.61 net volume Hz 31.51
2010 2.52 net volume Hz 32.06
I thought i had it figured out but my work computer has Version 2011 and the home computer has 2010.
So, which version do i use?
 What's the difference ?  I don't need an extra baffle with version 2011 to achieve the required Net volume and Tuning Freq.
                                            I did need the Extra Baffle on version 2010 to achieve the required Net volume and tuning Freq.
If this has been discussed before. I apologize.
Thank you in advance
DaveR
I would go with the newer version.  The difference between the two is in how it calculates the port volume.
Keep in mind that a .09 cu ft difference in net volume isn't going to make ANY difference in output.  Its just too small to matter.
Builds:
Thx for the response. I will go with the newer version.
I was looking forward to the second baffle and now that i don't need it, i was somewhat let down.
I know that.09 isn't much difference , it's just i am a sealed box guy hanging out in a ported world, i don't want to make any mistakes. Yall will look at me funny.
I am going to read the whole Torres' box tuning calculator thread as well. i am finding some valuable info in that thread.
I am also using your spreadsheet as well. Thank you for your assistance.
DaveR
  • Who's Online   2 Members, 0 Anonymous, 534 Guests (See full list)
