2 Sundown U10’s for sealed enclosure
tonksie93
I currently have 2 sundown SD3-10’s in separate 0.5cuft sealed enclosures. I am powering them with a ground zero gzna 1.2500dxii so when i start to turn it up the subs bottom out as there only rated for 500 watts each.
I quite like the look of the sundown U10, as they are rated for 1500 watts and have a high xmax of 30mm one way, which i understand is important for a sealed enclosure?
Would a pair of U10’s be a good upgrade or is there anything else i should look at in the same price bracket?
While the U-10s could take the power without reaching Xmax, they are actually going to have less output since they are more intended for a ported enclosure.  To come out ahead of your current SD3-10s you are going to have to increase your amp power a lot.
My suggestion would be to look at something like a Fi X10.  Even better yet, call up Fi and tell them what you want to do.  They can custom tweak some subs to work best for sealed applications.
Builds:
Thanks for the reply, yeah i wasn’t sure how they would work in a sealed enclosure. Out of curiosity, why would they have less output than the SD3-10? Do they have a lower sensitivity?
I’m pretty sure my SD3-10’s bottom out well before my amps maximum power. I plan to upgrade my subs first to utilise all of my amps power, then if my amp starts clipping before a desired SPL i will upgrade the amp too.
The reduced output comes from the U-series having a much stiffer suspension, which is great for high power ported applications,  not so good for sealed.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 2178 Guests (See full list)
