What is this phenomenom with Crossovers?
Qwiz
Oh. My. F. God! What am I going through lol.
This is somehow interesting. The end result has left me flabbergasted :))
I have redone most part of the wiring, in particular for the grounds. I have installed a distribution block under the rear seats, where all the grounds from the 2 amps and the HU are now going in. Then from there goes another wire to a polished bolt on thw right side, where the initial ground for the sub amp was.
Earlier the grounds from the hu and the components amp where sharing a bolt under the sleeve compartiment, while the one from the sub amp back there under the rear seats.
So now all gear shares a common ground and I have realized this, for me at least, made a collosal difference.
The settings on the PRS are:
- Sub 1 Mono, Sub 2 LPF 100Hz 12 db/oct Phase Normal
- Front HPF 100 Hz 6 db/oct
- Rear HPF 200Hz 6 db/oct
Internal Amp is On, Sound Retriever Level 2
Lpf on the amp phisically set to around 90 Hz.
I have noticed I get cabin gain around low freqs 50Hz or so. As I lean back towards the rear seats setting my seat lower I can notice it. But its ok.
And man, it finally seems ok now. Lol
  • Who's Online   0 Members, 0 Anonymous, 842 Guests (See full list)
