airofu Posted November 20, 2019 Report Posted November 20, 2019 Just wanted to clarify that setting my SSF and LPF with DMM on my amp is to multiply or divide by .707? I've read both and different for each.... I thought it was multiply to set a lower voltage for both eg: - SSF at 25hz - set volume get voltage multiply by .707 - play 25hz test tone and set SSF until i hit this lower voltage? - LPF at 80hz- set volume get voltage multiply by .707 - play 80hz test tone and set LPF until i hit this lower voltage?
airofu Posted December 16, 2019 Author Report Posted December 16, 2019 Just wanting to add more in, if I use an oscilloscope to adjust my amp gain, am I right to assume that if the voltage calculated is higher then what I thought I would get, I am simply getting more power from my amp before clipping which is good?
