setting gain help
29 minutes ago, Kyblack76 said:
Your backwards bruh.
OP, set fronts at 0 overlap, subs -10
What nominal load are you presenting the sub amp? 2, 4 ohm?
Is that some weird ass dual 4ohm sub... if so, theres your issue
Report back.
I'll try that. yea it's a dual 4 wired to 2ohm.
never knew the dual 4 had some problems. what is usually wrong with the dual 4s
Wired at 2ohm and rising to 7 or 8 your not gonna see dick for power. If any. There ya go.
20 hours ago, Snowy8171 said:
I used the dd1 and set it at the -10 db track. I should go up since it's a dual 4ohm sub?
Your not making any power wired 2ohm nominal bro. A DC 10k wired at 2ohm nominal, will see like 4k. If that.
  • Who's Online   0 Members, 0 Anonymous, 600 Guests (See full list)
