doughboi916 Posted May 8, 2008 Report Posted May 8, 2008 this all started today, i was at a red light and my lil bro turned the bass knob up, and the tach and speedometers started dancing with the music??? what can cause this?it never did this before?? and now it wont stop?? when im slapin at a cruse level everything is fine but once i crank her up everything starts dancing.
RamenNoodles Posted May 8, 2008 Report Posted May 8, 2008 Mine has always done that. Mainly the speedo. Not sure what causes it to do that, my guess is just all the movement and that thing is so small so its hard to keep still. Diablo Audio Technologies Fi Car Audio Ascendant Audio
ALPINE408 Posted May 8, 2008 Report Posted May 8, 2008 anyone else have this problem? i had that problem when my voltage droped around 10 to 9 volts alot crazy shit happends at that voltage! check your batts and alt! after i fixed the voltage the problem went away then i got another car with 18's and everything dance to the music no matter what lol Have you ever had your woofers blown?
doughboi916 Posted May 9, 2008 Author Report Posted May 9, 2008 ^^^^ good looking bro i pulled out the meter and the voltage is dropping to 10.5-11, my battery did die recently so i charged her back up and the BL just isnt hitting as hard ad it used too.
missinglink Posted May 9, 2008 Report Posted May 9, 2008 If your dropping that much do your subs stink from clipping. Low voltage like that kills the amps out put. If its clipping and you turn it up more the amp just puts off heat to your sub , and will not get any louder. That BL can take a beating but be careful with that voltage it smokes coils, not the subs fault just the sloppy power from the amps clipping. MLA missinglinkaudio The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
doughboi916 Posted May 9, 2008 Author Report Posted May 9, 2008 ^^^^^^ya got ya bro, you have a PM, since the gauges started trippin i haven't cranked it just for that reason, dont want my stuff burning up.
doughboi916 Posted May 9, 2008 Author Report Posted May 9, 2008 o ya, one more question?? it it bad for my equipment to be playing while the engine is off and i have a battery charger charging the batt? its prolly not even charging the battery since im playing music but i dont want to start my truck and i dont want the battery to die.
missinglink Posted May 9, 2008 Report Posted May 9, 2008 Should work like a power supply. Long term not sure. Wont be getting as much current as a power supply. Just keep an eye on your voltage !!! missinglinkaudio The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
