ehall8702 Posted January 20, 2020 Report Share Posted January 20, 2020 Anyone know if an alternator that may fit where the ac compressor is located on the 5.7l vortec? Seen a few Ford alternators that look like they would fit but haven't had time to go out and see if it'll fit my truck.i can get alternators real cheap and not looking to go to crazy with brackets and stuff yet. I will be fabbing a way to do it soon but not ready to go there yet. 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz Link to comment Share on other sites More sharing options...
Guest Posted January 20, 2020 Report Share Posted January 20, 2020 for 5.7 vortec chevy's, pickup or suv, you can get a dual or triple bracket that fits on passenger side, or a bracket that fits on the driver side next to compressor that holds up to 3. you dont need to get rid of the AC to fit even 6+ alts on these trucks. http://www.blueghost.org/ Link to comment Share on other sites More sharing options...
ehall8702 Posted January 20, 2020 Author Report Share Posted January 20, 2020 I don't have ac anyways and it's only necassry like one day a week here so I don't mind it being gone. 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz Link to comment Share on other sites More sharing options...
Guest Posted January 21, 2020 Report Share Posted January 21, 2020 ive seen people use simple angle iron Link to comment Share on other sites More sharing options...
ehall8702 Posted January 21, 2020 Author Report Share Posted January 21, 2020 48 minutes ago, Kranny said: ive seen people use simple angle iron Yeah I have thought about that also, I have a plasma torch so I can make it a bit nicer than angle but I'm a mechanic and I've noticed some of the Ford alternators have what looks like the same pattern as ac compressor ( 3 bolt not 4 but prolly would work). That's kinda what I was getting at...I'll take the next alt I take off a Ford and see if it fits, may be useful info for others, thanks for the links tho when I'm ready I'll be adding a few alts with prebuilt brackets 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz Link to comment Share on other sites More sharing options...
