Need some help with amp choice
KillaAkuma
So I am trying to determine best amp out of the two I have been looking at. This will all be run off factory HU not looking to switch as car runs off of the infotainment system just trying to add on.
Single. Woofer: Solo-Baric L7 12". Impedance: 2 Ohms. Power Watts: 1500 Peak / 750 RMS. Sensitivity: 86.9 dB 1w/1m.
Box Top Depth: 14-3/4" (37.4 cm). Box Bottom Depth: 17-7/8" (45.5 cm). Box Height: 16" (40.6 cm). Box Width: 18-3/4" (47.6 cm).
the amps I’m looking at are Taramps Bass 1200.1 1ohm
or
Orion XTR 1000.1
from my research so far the Orion is power hungry this won’t be a comp setup just a daily driver so wattage isn’t a concern as I won’t be pushing it just normal volume levels and the amp won’t be turned to full gain as it will probably smoke the sub. So my question is which one? They both run around the same price and they are both under rated according to BMDwiz dyno runs of these brands. So help me out here.
  • Who's Online   1 Member, 0 Anonymous, 1143 Guests (See full list)
