Sounds very good. Even tho everyone says the 15's aren't very musical and sloppy.
I can play down to 20hz at full tilt if wanted, granted the output isn't very high. Box is tuned to 41 and change. But most music I listen to doesn't dip lower then 30 mainly anyway. And the output is there at that freq.
Will have scores tommorrow night. they meter at window with drivers window down if choosen. Will try a run sealed maybe, just to say what it does that way.
The mj-18 blew that theory right out of the water. Its one of the fastest subs ive ever heard.
Car-96 blazer 4 door
Amp- Us-Amps M2D2
Front stage- Infinity Reference Comps 6.5
Subs- Undecided open to all offers and opinions
You had to have it all
Have you had enough
You greedy little bastard
You get what deserved
When all is said and done
I will be the one
To leave you in your misery and hate what you have become
looks good man, nice build, nice fit, looks like it sounds great
Amps clamped imp rise to 1.9 from the strapped .5 isn't to bad. Full charge and burp off 14.1 I got over 2600 out of the strapped pair. Little more then there rated 1200 each at 1 ohm. Couldn't be happier about that. Didn't meter off the first clamp tho.
Did a 135.8 with a clamped 500 watts and 143 and change with a clamped little over 2000 watts. Not sure what the prob was, beside maybe the weather. Going to redesign maybe. Wife will decide if she wants it changed or not, since it is her vehicle now.
Voltage was a constant 13.8 after the first test. Could do an easy sb or br run with voltage only dipping to 13.5 the whole run.
Next vehicle will be better and go all out for the higher score. Already have the car,amp and wire in the works for that build. Will post a log once it starts.
  • Who's Online   1 Member, 0 Anonymous, 1230 Guests (See full list)
