Alright, ive been trying to find a solid answer all over forum's,maybe I'm not looking up the right question or im over thinking it so.
I want to put
-(2 amps on 1 dual, 2ohm sub)
-Amps do not have link option, and are able to operate 1 ohm regularly
Amps show 2 rca female inputs
-Top labeled: input
-Bottom labeled: output
My headunit, has one set of rca pre sub outs,(will upgrade eventually.) Will a regular female to male splitter work for the input, and output to get signal to my amplifiers.
What i do know or think i know
- both amps must be same
-speaker output level must be matched
-wire both amps to each Voice Coil. (But with 1ohm,2ohm, or 4ohm subwoofer dual coil)
- both amps (+ to +) and (- to -).
To set match gain i will be doing the *Barevids method*
-gain match amps to output level
(example 35.3v) or whatever ill be doing with ocsope just below clipping or close to common output voltage.
-wire amps + to +      - to -
- low volume, low power, start 20hz tone
Just until some vibrations come out of the speakers. (Again very low power, only to feel movement)
Go to 1 of the amps, flip polarity on 1 voice coil, again stil that very very low power.
-Adjust gain on that same up until minimal vibrations are felt.
-then adjust phase, until NO vibrations are felt at all.
-STOP TONE, flip back to regular polarity.
And amps are matched.
Questions:
1) how do i get signal to both amps (rca)
2) do i get more power?, if both amps are working the 1ohm impedance. Or if because this isnt strapping ig,
on a (dual 2ohm sub, 2 amps) they'll work the 2 ohm? because their wired to each coil independently?
*Or does the impedance still get cut in
half wiring this way.  1 amp 1 coil (+ to +) and (- to -)
Other amp, other coil of the same sub (+ to +) (- to -). On a dual 2ohm sub.
-If i dont get more power with a 2 ohm subwoofer, how could i get more power to a single sub with (2 amps on 1)
vs  (1 on 1)
-i deeply apologize for the length of this..
Just making sure i get good answers, and also dont get any wasted information for people later on like me trying to find this answer.
Equipment i plan to use because of want and budget.
2 O-2400.1 wolfram amplifiers
1 ZVX15 d2
I know ill be told 1 2400 is enough. Buuut That's not what im here for. Thank you for your time, and consideration for reading this much love, and thank you to all bassheads.
-Ps. High output alternator is already on the way.
1 o-2400 is already ordered
