Hey i have a question..I have 3 12 inch subwoofers. they are Kenwood KFC-3011.. they have a 1200 peak power and a 400 RMS power and are 4ohms each speaker. I want to get an amp for it but the info they give me for this amp is so confusing.can anyone help...............................Amp info below
1 New Ultra-Linear UL1202 High Performance 2 /1 Channel Amp
Power Output:
1 x 1200 Watts RMS @ 4 ohms
2 x 600 watts RMS @ 2 ohms
2 x 300 watts RMS @ 4 ohms
2-Ohm Stereo Stable
What is that crap talking about in the colored specs?. i thought i knew how to match the amps and subs until it put all this stuff on there...im confused...
Power Output:
2-Ohm Stereo Stable
Meaning your amp will be running at 1.33 ohms if it's stable at that. If not, it'll probably shutoff.
Power Output:
2-Ohm Stereo Stable
Check out the post in the subwoofer forum on Ohm loads:
http://www.stevemeadedesigns.com/board/ind...p?showtopic=788
Basically since you have 3 subs to hook up and your amp is only 1 or 2 channels you gotta wire the subs together. Depending on if you wire them in series or parallel the resistance your amp sees will not be the 4 Ohms your speakers are rated at. All the subs wired in series would mean 12 ohms for the amp while all 3 in parallel would mean the amp sees 1.33 Ohms like SteelCityGhost said.
how did u come up with this 1.33ohms from??? thats only if they are Dual 2 Ohm Subwoofers 1.33 Ohms would be achived in Series/Parallel.
this is what ur REALY gonna have for ohm load, Dual 4 Ohm Subwoofers 2.67 Ohms this is also Series/Parallel. or if u want to Parallel/Parallel
and run ur subs at 0.67 Ohm u can but i dont think that amp is .5 ohm stable.
im a wireing guru and ill draw out any wire config u want let me know. i wire my subs Parallel/Parallel @ .25 ohm for comps, Series/Parallel daily @ 1 ohm.
as for ur question u can run a 1200wrms amp to power all three subs but not that one id look for. id get a 2 ohm stable mono amp thats 1500wrms cuz of the 2.67ohms not being a tru 2 ohm load u will not get a full 1200wrms maybe 1000wrms and u have to include impeadance raise and box rise. so a 1500wrms amp that will run 2 ohms would be perfect. remember to set ur gain with a DMM to proporly set so u wont send any clipping signal to subs that can damage them.
Edited by lil_italy773
that amp wont work. You need one that will run 1 ohm mono.
....and who the hell is okcchad?? there can only be one person on here from okc. :D
Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA.
1.33 is correct.
a single 4 and a dual 2 has the same final impedance if the dual 2 coils are ran in series.
Edited by SPL2K
Okc is where it's at!! I sorta thought I would be the only one here, what little bit I am here :)
And I didn't bother looking up the subs, but if they are 4 Ohm SVC like the post suggested then 4 || 4 = 2, 2 || 4 = 1.33. I make no suggestions on if it's good or not (doesn't sound good), I just like numbers.
ok they are single VC damn how many subs are that anymore not very. ok then they would all 3 be 1.34 ohm load i just did the math 3 times on my calculator. i dont use the wireing wizards when i am one on paper.
u can either run a 1ohm mono 1500wrms amp safe or a 2 ohm 1200wrms amp to keep the wattage close to peak for the ohm load. but id go with a 1 ohm stable amp, and watch ur gain its key in setting up.
Ummm. I'm a little confused now...there are different answers here...so i should get a mono amp with 1200 Rms or what?
thats my fuck up thought they were D4s. u dont see very many single VC subs 3 or more ran together thats all. get u a 1 ohm stable u'll be fine
  • Who's Online   0 Members, 0 Anonymous, 2876 Guests (See full list)
