Amp Question
jigglenuts
i was wondering if anyone has played with any power acoustik amps. i was just lookin around at amps and seen the A3000Db and PS1-5500D just curious to see if they have ever been used. IF so how do they do and do they hold up.
i've seen the A3000Db compared to the Brutus Line by Hifonics, Bang for buck cheap amps that put out watts (although usually not rated with weak voltage)
-Drew
uhoh_45 said:
I have a couple friends that were using the A3000DB and were completely satisfied. It puts out a lot of power, and is a good buy for the price. Amp has been running strong for almost 4 years now, w/no problems.
Guest Caps
those are the only two that i have liked, i run the 2400db now, and its not really worth more than 1600rms.
Well depending on your electrical system, that will determine what wattage you get out of them. With a stock electrical, you're probably looking at about 2000 rms. If you're running 16 volts or near it, you may get close to the rating they have listed, 2300 rms at 1 ohm.
  • Who's Online   0 Members, 0 Anonymous, 1096 Guests (See full list)
