Maxspeed996 Posted March 10, 2021 Report Posted March 10, 2021 I'm laying out the plan for a complete system in my truck. 2012 GMC Sierra extended cab. I'm starting under the hood with a new battery and new and additional wiring for "The big 3". Mechman alternators say that the lug that attaches to the positive post of the alternator HAS TO FIT EXACTLY or it could heat up and cause heat buildup, melting , fire... Has anyone found 1/0 lugs that have holes on them smaller than 3/8 (which seems to be the standard size everywhere I've looked)? Or is this something I should worry about? Even the factory high output alternator only had a 10mm stud for the positive so I wonder what others have done. Thanks for the space.
Masterbasser Posted March 11, 2021 Report Posted March 11, 2021 del city has alot of different siuzes, so does amazon. not hard to find. make sure the lug hole matches the stud size which is 5/16 or u can melt stud off like i did once long ago. do no use 3/8 and call it good. Kenwood excelon ddx795 3 370 amp CES alternators (audio side only) McLaren dome tweeters Crescendo 6.5 ultra neos NVX JAD800.4 4 PA x4 SPL 18's 4 Digital Designs m5's at .7 ohms each 2 K2 80 ah lithiums 3 group 31 agms Ledglow million color (12 piece) 2007 Yukon xl
