killerc998 Posted April 21, 2021 Report Posted April 21, 2021 Has anyone else tried them yet? I installed them in a 1999 suburban with a sbf 200.4. The doors are treated with fatmat maga which is the butyl stuff. Going to add mlv between the door and the door panel to see if it helps. Amps tuned with a dd1. Used the 0db track (its the track i always use) got max volume of deck prior to amp install. Running 2/0 welding wire to a distribution block, from the block to amp is 4 awg welding wire. Im not loosing any voltage. Passive crossover set to 0db. The mid bass leaves you wanting more, seems like they fall off around 90hrz. Not sure if the passive crossover is set that way. The tweets sound good and clear. Volume is lacking, the sound with amp is almost the same as off the deck. Amp pushes around 50rms per channel more then deck. To me it seems as if the B2 Audio Rage 6.1 is over rated and should the rms should be rated @ 50rms or less. Not the 75 rms it is rated at. If anyone has any thought on this let me know.
