jrwilshire2003 Posted May 3, 2021 Report Posted May 3, 2021 Hi all, I've got hold of a Titanium 800.1 amplifier to run my 15" subwoofer. I'm having issues setting it up. I"m new to these Titaniums but have had tons of other amps before and maybe comparing it to them. The issue I have is I can't change any of the low pass frequencies, bass boost or bass boost frequencies whilst it is in LP mode. The only way these become active is when the amp is set to BYPASS. I would have thought that even in LP mode you should have control over these functions? When in BYPASS mode all these features work and can be heard working but in LP mode moving them all doesn't make a single bit of difference. The only control that makes a difference is the high pass frequency knob which i'm not sure why is on a mono amplifier really lol. Maybe there is something wrong with the amplifier or just user error? Any help would be appreciated. Many thanks.
Wifebtr Posted May 15, 2021 Report Posted May 15, 2021 Can you run the amp in bypass, and run the low pass frequency through your head unit?
