mcnaught82 Posted May 16, 2008 Report Posted May 16, 2008 I want to install 3 GB of memory into my PC I have 4 Slots, I want to put 2 1GB Chips and 2 512 Chips. I had a place tell me today not to mix memory like that cause it will cause a problem. Is that true? Or should I just put 4 1GB chips, and loose the 1 GB because of the 32 bit system. Quote Team Deadly Hertz
Shibby Posted May 17, 2008 Report Posted May 17, 2008 Why couldnt you do 3 1g chips, Im not 100% on memory but i dont see why you couldnt do 3 1gbs Quote
Applejack Posted May 17, 2008 Report Posted May 17, 2008 you can do that if you want. just pair the memory in the slots. if i were you id buy 3 1 gig sticks of 800 mhz, assuming your boards highest rated handling speed is 800mhz. and ddr2* Quote Midwest Car Audio is on facebook! http://www.facebook.com/pages/Midwest-Car-Audio-Association/101253286585630
Sp33dyG Posted May 17, 2008 Report Posted May 17, 2008 u can mix up the memory BUT they HAVE 2 be the same brand and the same speed Quote the only person i wouldnt let build my box would be Ray. Team Heavy-Flex4 SA 12's tuned to 29hz Ampere Audio 3800.1 @ 1 ohmXS Power D3100Big 3Stock alt
TrippiN Posted May 17, 2008 Report Posted May 17, 2008 Mixing memory (sizes) wont cause a problem. Just dont mix up the type. Like adding 2- 1gb PC6400's and 1 PC3200 or something. As that could cause problems, and make the memory run at the slower speeds, even faulting the sticks. As for the brands, i never heard anyone say you must stick with the same brands. I got a 512 patriot 3200 and a 512 kingston 3200 on my other pc, and never have any problems with it. Quote
mcnaught82 Posted May 17, 2008 Author Report Posted May 17, 2008 Its an HP system and it only takes DDR. This is the memory. OCZ DDR PC-3200 / 400MHz / Value Series / Dual Channel 400 MHz CL 3-4-4-8 (CAS-TRCD-TRP-TRAS) Available in 256MB, 512MB, and 1GB modules 512MB (2X256), 1GB (2X512), and 2GB (2x1024) Dual Channel Optimized Kits Unbuffered Lifetime Warranty 2.6 Volts 184 Pin DIMM Quote Team Deadly Hertz
audiofanaticz Posted May 17, 2008 Report Posted May 17, 2008 As long as the memory chips are all the same speed it wont matter. If you stick a faster stick in with a slower stick, the faster stick will run at the slower sticks speed. Another thing to watch out for is voltage of the ram sticks, and the timmings. Some memory sticks require more voltage for proper use, and some can take more then other sticks. Brands, sizes dont matter to much. For the average user you wouldnt notice these small things much tho, but to a serious gamer or overclocker, this could kill the speeds they wanted to reach. Quote
mcnaught82 Posted May 17, 2008 Author Report Posted May 17, 2008 As long as the memory chips are all the same speed it wont matter. If you stick a faster stick in with a slower stick, the faster stick will run at the slower sticks speed. Another thing to watch out for is voltage of the ram sticks, and the timmings. Some memory sticks require more voltage for proper use, and some can take more then other sticks. Brands, sizes dont matter to much. For the average user you wouldnt notice these small things much tho, but to a serious gamer or overclocker, this could kill the speeds they wanted to reach. Thanks. Quote Team Deadly Hertz
Tub Asko Posted May 17, 2008 Report Posted May 17, 2008 (edited) www.crucial.com every thing you need to know Edited May 17, 2008 by Tub Asko Quote Facebook Youtube Murdered '07 Silverado
mcnaught82 Posted May 18, 2008 Author Report Posted May 18, 2008 I talked to HP and they told me I cant install that memory because it is 2.6v and the memory that came with my pc is 2.5v. they said it will damage my memory slots. Are they talking out there ass??? Quote Team Deadly Hertz
