Can someone plz help me out
Joshk
Hi, every time i try to use subbox pro or winisd it goes crazy . im trying to get blprints/ measurements for and enclosure .plz any help is welcome.  If possible center port 2 skar vxf 12s d4 tuned at 32. Id like 2cbft^3 per sub after displacement. My max dimensions in trunk are 13h,36w,24d. That would fit in nicely.  Im running 3k smart taramp.  Im going to wire final 1ohm to amp. The displacement for one VXF-12 is 0.233
  • Recommended Ported Volume: 1.80 ~ 2.00 ft³
  • Recommended Port Area: 29.75 in²
  • Recommended Tuning Frequency: 32 Hz
  • Enclosure recommendations above do not include subwoofer, bracing, and port displacement
SUBWOOFER MEASUREMENTS
Cut-out Diameter 11.13"
Mounting Depth 8.50"
Total Height 9.33"
Outside Diameter 12.49"
Magnet Diameter
8.63"
12-inch Dual 4 Ohm Voice Coil Configuration
Peak Power: 3,000 Watts
RMS Power: 1,500 Watts
Competition Grade Pressed Paper Cone
Stitched High Roll Foam Surround
Advanced Air Flow Cooling System
3" High Temperature Copper Voice Coil
Motor Weight: 300 oz
Frequency Response: 22 - 250 Hz
Sensitivity: 83.6 dB
Fs: 34.4 Hz
Re: Dual 4 Ω
Qms: 4.46
Qes: 0.47
Qts: 0.43
Mms: 319.9 gr
Nref: 0.19%
Cms: 0.07 mm/N
Bl: 33.8 n/a
Vas: 22.7 L
Sd: 471.4 cm²
Xmax: 25 mm
If you need to go wider you can go up to 40 and deep you can go 28 if needed. Thank you
  • Who's Online   1 Member, 0 Anonymous, 1694 Guests (See full list)
