Sundown Audio Salt 3 amps linked go full out when power on vehicle
Bought new amps. Took out old and hooked up the brand new (2) sundown audio salt 3. Linked them together. When I turn the car on, full blast power thru the sub. Everything is hooked up as shown in manual. Have had 2 other people look at the insta and they said the same thing. Everything is right. Only thing I can thing is... I bought a rca wire to go from master amp to slave amp. Could I have gotten a bad rca and that's causing the problem?
I tested each amp and they work great individually. Linking them in another story.
Pic is after I unlinked the 2 amps. Currently waiting on Sundown Audio technician to return my call.
Did you link them through the master/ slave RCA output? Or the 2 RCA outputs next to the inputs?
I picture of the side of the amps where you connected them would help
