Winging it...
Blade73
On 10/29/2022 at 10:46 AM, Joe X said:
To offer you some more help, you have used the external volume instead of the net internal volume in that port length calculator above.
Even then the use of those types of online calculators is not recommended, in this case that calculator is not valid for slotted ports, just for ports with no common walls, like an aero port.
Thank you for the explanation. I took a break because I got frusterated and started making mistakes. I'm considering other options now after a lot of reading.
I'd like to save some space and it would surely simplify things if I just did a sealed box. I've been checking out the SSA Demon. I could do 2 10's and keep the box fairly shallow. I guess my goal is to be louder than the older 500w type r I was running in a ported box that was probably too small because I built it to Alpines "recommended box specs".
