I'm about to buy my bros computer and I'm wondering if anybody has run their computer off an external HD? It may sound weird but he has a nice gaming rig and I want to free up space for better cooling. I also read that the most serious gamers use two HD for gaming. Can I do that with the external and how would that work (setup wise)?
2012 Honda Accord
Radio: Pioneer AVH-4200NEX
you can run sata outside the case, but even if you could get it to work (im not sure, ive never tried it) I wouldn't even consider usb etc.
But yea, just hook up an external drive using sata
Guest Caps
you have to set it to boot from the external, but whats the point?
I thought that would be more reliable, cheaper to replace, and run cooler. My folks house stays hot.
Edited by ChampN252
2012 Honda Accord
It wouldn't change reliability... possibly lower it though due to it being around other objects that creat interferance... you don't often have to replace hard drives, but it would be slightly more expensive to put in (due to needing an external case and an extra cord/plug), and the drive itself should be finewith temp, mine stayes under 30-35 degrees C all day. btw that is in a 5x5 closet that probably gets to 90+ degrees F when im doing my gaming with the door closed...
Now your case being cooler... can't tell you that unless I can get more info on your case.
