Guest Posted May 23, 2008 Report Posted May 23, 2008 I put in various subs in the program, made a custom file for each, and the specs were near perfect to paper specs. i put in the rms rating for the power, ohm measure. and the damn thing says that 2 12's will only hit 120db, 4 12's is like 125. do any of you have this problem? its kind of annoying
banginAltima Posted May 23, 2008 Report Posted May 23, 2008 That part of WinISD never works right. I believe those number are with the box out in the open, like its just setting on the ground. WinISD is really only good for finding port length at a given freq. If you build it, db's will come... NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09). Competition Only Record Holder Trunk 0-500 watts---148.1 2006 Nissan Altima 3.5 SE Currently Rebuilding.... My 150db Plus Trunk Build I do box designs. [benH] 6:24 pm: clipping doesn't really hurt subs [benH] 6:24 pm: being an idiot is what blows subs
tommyk90 Posted May 23, 2008 Report Posted May 23, 2008 That part of WinISD never works right. I believe those number are with the box out in the open, like its just setting on the ground. WinISD is really only good for finding port length at a given freq. x2 I've never used it for anything else since in-car response is most likely going to be completely different anyways. Team B2, Team Audiotechnix, Team Kicker, Team XS Power, Team Sundown, Team Maxxsonics, Team DD2008 Bassrace 130-139.9 Regional and National Champion2006, 2007, 2009, 2010 and 2012 MECA Champion (S1, SR1, S2, S3, S4, DB1) -1 DD 9510F + 2 Sundown SAZ2500's @ .7 ohm strapped=154.2 headrest, 129.2 driveby-2 DD 9510F's + 2 Sundown SAZ2500's @ 1 ohm strapped=154.0 headrest-1 DD 9512F + 2 Sundown SAZ2500's @ 1 ohm strapped=153.5 headrest, 131.1 Driveby -2 DD 9512F + 2 B2 Zero1's @ .5 strapped= 157.0 headrest, 158.0 outlaw-1 Sundown SA-8 + 2 MB Quart 2000's=148.8 headrest, 150.6 outlaw
