just got my heavy ass 5 gallon bucket of putty. probably going to go work on it now. finish up the inside. should i fiberglass the outside?
Clarion ProAudio VRX755VD
Infinity Perfects 6.1-front
Infinity Perfects 5.1 -rear
Infinity REF7541A
3 Kicker S15L7D2
Kicker ZX1500.1
Kicker ZX750.1
Pair of Memphis tweets
New Build In The Works
The resin putty was supposed to be delivered to my house this morning, and the guy called and said he would do it after work. so... i finished the outside of the box construction, and made a slight change to the design.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
i changed the front side of the top. the thin part of the design broke, so i just started cutting peices to make it the way i wanted it to look, and just came up with this
Hey man just a question....do ya have a router...if yes I have a trick that will save you a ton of time doing the cut and shit around the port...........looking good so far
i have a small one, but it didnt cut it too fast, so i just got the jigsaw and cut it out, and it cracked, so i just tore the bottom part out, and put in some 3-3/4" peices to make it look flush
Infinity REF7541A
3 Kicker S15L7D2
Kicker ZX1500.1
Kicker ZX750.1
Thats cool..next time if your router cooperates just lay the wood over the whole thing,drill a small pilot hole where the ports are and then just router out the ports,then go over them with a round over bit....but I'm guessing you already knew that..
i drilled a hole in the corners, and in the midpoints, to show where my marks are before i cut out the corners, assuming the hole saw would cut the paper like it did, then got a metal straight edge and a razor blade, and drew a line with it
Infinity REF7541A
3 Kicker S15L7D2
Kicker ZX1500.1
Kicker ZX750.1
? - what does glassing the inside and outside do for the box?
?2 - Should i glass the outside? or should i just leave it the way it is
Infinity REF7541A
3 Kicker S15L7D2
Kicker ZX1500.1
Kicker ZX750.1
It would make the box stronger, but glassing the inside should make it strong enough.
Head Unit: Pioneer DEH-P4050UB
Subs: 2 Pioneer Premier 12" ts-w3004spls
Sub box: 3.2ft3 tuned to 35hz
Sub Amp: SoundMagus DK 1800
Speaker Amp: Rockford Fosgate 200a4 Bridged to fronts
Front Speakers: DLS MS5A components
2 gauge power & ground
thanks. im not looking for 160db's im just looking for a box that pounds, i want it strong, but not stupid. i guess the word would be "extreme"
Infinity REF7541A
3 Kicker S15L7D2
Kicker ZX1500.1
Kicker ZX750.1
would a regular sander work? to make the speaker hole bigger. it is an 1/8" to small right now.
Infinity REF7541A
3 Kicker S15L7D2
Kicker ZX1500.1
Kicker ZX750.1
the sub holes are too small, i had to do a lot of dringing tonight, and they still dont fit. 13-3/4" is not enough for the subs, im at almost 14" now and its still rubbing.
Infinity REF7541A
3 Kicker S15L7D2
Kicker ZX1500.1
Kicker ZX750.1
