Guest beatitouttheframe
if i used  0ga wire for my power do i need to use it for ground or remte.....and would it matter if i used  biger speaker wire????? like a small power wire...?and if theres anyone geting rid of some 0ga hit me u i need it befor this wekend local audio sho and im trying to put somthing togather but im out of wire
If you're gonna make all your power cable to 0 gauge, then make sure your ground is 0 gauge as well, it'll coordinate better because you're giving it freedom on 1 end, then choking it on the other :-[...dont worry about your remote wire..and in terms of speaker wire, it all depends on what you run..if your running psycho stuff like MTs or BTLs or similar, then you can go down to 4gauge speaker wire...i am running a T1 12 and i use 8 gauge speaker wire..and 14 gauge for my speakers for 4 channel.. I could even use 12 gauge for my sub to amp, and 18 gauge for speakers without loosing a lot of flow..hope that helps
I see Booty
2007 Toyota Camry
19" VMR Rims
H&R Lowering Springs.
Magnaflow Exhaust System
K&N Air Intake
6k HID Projectors & Fogs w/ Black housed headlights.
Optima Yellow Top - Front. Kinetik HC 600 - Trunk
Kenwood KVT-617
Rockford Fosgate 3sixty.2
Rockford Fosgate T2001-BD - Sub Amp
Alpine MRV F-345 - Front stage
Front Stage - A pillars - Dayton Audio 4" mids w/ Vifa Tweeters
Front Doors - Vifa - 6.5" midbass 1" Vifa Tweeters
Subwoofers - 2x 12" Image Dynamics IDMAX - 2.91 cuft ported enclosure tuned at 25hz
a lot of places have different prices..go look around online, or if you have shops in your town that have it for cheap..it varies..It's about $4-$5 a Feet here in toronto for stinger or KnuKonceptz
I see Booty
2007 Toyota Camry
19" VMR Rims
K&N Air Intake
Kenwood KVT-617
damn thats alot lol i need like 15ft
that's why I said, go look around shop in ur town, talk to someone and get a deal maybe?  never hurts to try.. last resort just ebay that shit
I see Booty
2007 Toyota Camry
19" VMR Rims
K&N Air Intake
Kenwood KVT-617
true that bro...ill look around in the mean time  anyone got a 0ga wire for free or dirt cheap...????
Guest MegaloManiac
use the same guage as your power as for ground(or a bigger for ground, never the other way around)
If your using 0 gauge power then use the same ground or bigger. I like having the remote size around 16gauge, a little thicker.
