Ill take some pics the next nice day, my system is just thrown together nothing fancy right now. I'm trying to teach myself how to make some good quality boxes. I'm trying to figure out how i can build a box that will fit snug against the back of the rear seat, the trunk isnt flat it has a incline for the spare tire which i removed from the car. Ill take some pics maybe you guys can give me some ideas and a few pointers since im just starting out in the whole car audio world. I had 4 systems already but the system i have now is the first one i hooked up on my own.
Like i said in earlier post i JUST put this in nothing fancy yet, but heres what i have. Its a shitty job but at least its something.
If you guys can give me any ideas on building a box that will fit against the back of the rear seat i am open to suggestions. As you can see in a few of these pics the trunk has an incline for the spare tire so the universal box i have has to sit at the very front of the trunk.
okay there are a couple of issues that I can see right now..
1 did you fuse the power wire within 18" of the battery?
because you have an inline fuse in the trunk and its not nec,
2 you dont have a good ground... you need to ground the amp to the frame.. not that flimsy brace
3 your wiring is a mess, you should get bigger wire and run everything again or atleast clean it up until you can get bigger wire... that 8/10ga isnt gonna cut it meng.
as far as building a box that will sit flush against the back seat its pretty much pointless due to the irregular shape of the spare mount and the minimal height from the floor to the rear deck. that coupled with the fact that the rear seat doesnt fold down that would be pointless. Im working on an idea to where I can get the seat on my Impala to lay down. until then just get a jigsaw, cut the rear deck out, and spend some cash on dampening material.
to get the trunk rattle under control.
Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
Yeah the power wire is fused 12" from the battery, a local shop threw that 2nd fuse in i dont know why buy they did. I was planning on rewiring everything cuz all of the wiring was done on my 1st system by a local shop. The power wire is a 4 gauge but when i rewire im gonna upgrade to a 0/1 gauge. The irregular trunk pisses me off, my system could be much louder if it was flush against the back seat. The only idea i could come up with is removing the back seat completely at throwing in 2 bucket seats, and building a wall that sits between the 2 bucket seats in the back and in the trunk build a false floor and put all the amps etc back there.
you dont have to go that route, you would lose a ton of output wit a box right against the back seat...my box is about 2-3" from the trunk latch and it fires to the rear and I have no problems with getting pressure into the cabin. you have to take into consideration that you have a trunk car and you arent using very high end equipment. aside from building a wall your best bet is to rearfire everything with the deck cut out or make a bandpass and port it through the rear deck. I can get you a few pics of mine if you need some ideas as to what to do
rear deck
6.5^ft net 27hz tune
Ill snap a pic of the underhood wiring and of the frame grounds tomorrow... I cleaned up the wiring later I was just in a hurry to get it all playing
Edited by Pitbullx
That actually gives me a few ideas, did u just cut the rear deck out straight through. My original idea was to cut the rear deck completely out then replace it with MDF and build the box off of that, since the trunk is so oddly shaped. I'll take some pics of my rear deck today and maybe draw up a little picture to help explain my idea a little bit.
rear deck is too narrow to put anything there besides a port for a bandpass......... actually a front firing bandpass ported through the rear deck would be nice in this body style car. but they are huge and too complex to design/build for most novices....Im taking all of mine out over the summer and stepping up to 4 BTL/9512s and 2 T4000s ported in the trunk
I wanna upgrade my system to 2 Fi BTL's but i gotta save up some cash b4 i do that. Pitbull do you have yahoo or something? it would be a lot easier talkin over yahoo than on here, throw some ideas around since we have almost the same car just different year. :D
