Looking Sub Enclosure Design
gewaun
I will gladly pay if it's not to much for a enclosure design. Looking for a enclosure subs up port back with port in the middle for 2 15's. They will go in a 96 2dr. Yukon gt max length of compartment is 48" , window line 18", top of back seat 20" from back seat to tailgate 36". I will like to use more of the 48" across the back  space to make the enclosure wider than longer if possible. The subs being used 2 Resilient Sounds RS 15 500 RMS Entry woofers will be power with a Rockford Fosgate Prime 1200.1 amp. I was looking for the enclosure to between 5&6 cubes 33hz if possible since the sub will never be over powered.
SUB SPECS
RMS: 500
MOTOR: 130oz
SPL: 87.9dB
FMS: 27.3Hz
BL: 21.0
Res: 58.0
Re: 7.6
Qms: 5.44
Qes: 0.72
Qts: 0.64
Cms: 0.14 mm/N
Mms: 244.6 gr
Nref: 0.39%
VAS: 142.2 L
Rp: 61.3
Lp: 71.2 mH
Cp: 593.2 uF
Le: 3.82 mH
Xmax: 17
  • Who's Online   1 Member, 0 Anonymous, 772 Guests (See full list)
