Need Some Help With Ohm Loads
sorry for posting a noob question...its hard to search for something like this because of how the search is setup...
so i want to know the wiring options i have with 2 dual 1 ohm VC subs. i cant find diagrams anywhere. basically im going to be buying 2 Fi SSD's but i want the load to be 1 ohm to the amp...i know if i get both subs at 2 ohm i wouldnt be able to get a 1 ohm load total so would it work with both subs being dual 1 ohm?
thanks..
-kev
12" fi q
rf t10001
naw mean
either .25, 1, or 4
ill try to find a link with the diagrams
NoFearX18 said:
trainman0978 said:
rockford wiring wizard
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
they dont show wiring for a 1 ohm sub. they only show single 4&8 or Dual 2&4
NoFearX18 said:
trainman0978 said:
u can either go 2ohm each sub then in parallel to 1ohm, or .5ohm then series to 1ohm? like + - to + then - and use the + and - on each side on each sub to get 2ohm then wire down to 1ohm, or go ++--++-- and then take 1st pos hook to amp and wire the - to the pos and take the neg and go to amp, i dont kno if this discribes it good enulf but i tryed
either .25, 1, or 4
so i COULD wire 2 dual 1 ohm subs up to a 1 ohm load total, right? reason being is i want to get another rf t1001bd and wire up the ssd's @ 1 ohm. this is for a friend btw so i wanna make sure its possible...
thanks chode..
12" fi q
rf t10001
naw mean
thanks chode..
yes sir
and anytime bro!!!
NoFearX18 said:
trainman0978 said:
^^^ perfect
i havent been to the12volt.com in forever
heres the diagram your looking for kevin
NoFearX18 said:
trainman0978 said:
  • Who's Online   1 Member, 0 Anonymous, 1612 Guests (See full list)
