been talking to a friend about this and thought ill get some more advise about it since asking dont hurt. I am wanting to know how to meter you amp output for setting the gain right with the headunit, so i dont have the gain to high or low. Also is there a meter to measure how much watts are being put out of the amp. If you have links to these meters that would great...thanks mike
PS: order my Fi BL 12'' woofer last night
2 AQ 10'' HDC3 copper subs
1 3500d AQ amp
146.3db on TL with stock electrical in single cab truck at 32hz
RESULT: 1st place at comp, 3rd overall out of 20 cars
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
