the reason i asked about the battery under the hood was i read that different batterys had different resting amps or somthing like that so i didnt know if mixing brands was good or not
meade has a yellow top under his hood.. and  teh pc2150 batterys in the back.. its fine.. an AMP is an AMP, same as a VOLT is a VOLT
SMDsigbannr4.jpg1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
i haven't had any experience with the kinetiks yet but i'd probably do that one over the yellowtop.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
kinetk is $ for$ better
i called up kinetik and talked to a guy name Eric and i told him about me having a dual purpose yellowtop under the hood and i wanted to know if i could keep the yellowtop and add the HC800 in the back. well he told me that i could use them both but the HC800 would outlast the optima and that i might want to look into getting the optima changed over to a kinetik 2000 or 2400 in the front. so that's that
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
ok i think im going to go with the kinetik hc 800 and 2400 but about wire is one run of 0awg going to be enough and what size fuse am i going to need to use
fuse to teh mas recommended amperage of the wire 1/0 is 300 amp
Eric is the man when it comes to batterys
i've been rolling with optima since 2000 and they haven't let me down but i think it's time for something new and all the hype about kinetik ............ mightest well try it. besides you can't beat the HC600(100 farads for around $99 on ebay) and the HC800(200 fard for around $120 on ebay). that's just too good of a deal.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 4348 Guests (See full list)
