battery pretty damn new and no audio was hooked up but the big 3 upgrade and the new alternator. i have pulled on the fuses and still get that 2 volts between the grounds.
i still dont know wut u mean by the grounds, grounds should have no power so your good, or can you explain?
i was told thats the way to find your drain is but a multi meter on your grounds and pull fuses till there is no voltage.
touching the grounds will not help you find your problem, just start disconnecting the power wires that you ran 1 by 1 untill the draining stops, but if you dont have anything connected then im starting to think somethings hooked up wrong or your battery took a shit
I don't get it.
Are you trying to figure out how much current the car is pulling when everything is off and the key is out of the ignition?
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
Is the battery sitting at 2 volts?
For some reason I don't get the question.
delete
Edited by ISO
  • Who's Online   0 Members, 0 Anonymous, 876 Guests (See full list)
