ok. i found a iraggi 200 amp alt but it puts out 12volts.....my mechanice said i need one that puts out more than 12 or it wont charge right. but it cant be more than 13.7 volts. so my ? is does iragii make more than 12v alts?
Get you a MLA module down in the bottom of the forums in the manufactures forums that will make your alts push out any voltage and 13.7 is not the most you can go 15.3 will run fine.
2 18'' fi btls fully loaded
2 sundown saz 3000d
1 iraggi 200 amp alt
3 powermaster 3100d series batts
11.75 cuft wall after displacement tuned to 31.08 hz
Lol, all Iraggi alts will push more than 12volts. pretty much every alternator will push as much as you allow them to. It all really depends on your battery. If you have 12volt batteries you can put around 15.5 or so and if you have 16 volt batteries you will have even more.
In your case, you have a 12 volt battery which you will want to upgrade as well. A simple Optima Yellow top will most likely work well in your case or the biggest Kinetik/Powermaster you can fit in there as well.
$540 to fix an alt!???! you got jipped imo
E.A sells some alts for a good 300 or so
540 bucks with the alt included in the price. its 280 to put it in cuz u gotta take out the front axel in my car to do it.
Well a 12v is not really needed when ordering an alt. So common HO replacements will be a standered voltage unless you ask for something higher then it will be a special order. All automoive alts that will fit on cars can be any voltage. You can get a stock alt from auto zone and run it at 19v that number really dosen't desribe an alt. You just need an alternator is all. The alt willl put out around 13.8-14.2v in most cases. The voltage is maintained by the internal regulator in the alternator and/or your cars computer anyway so just ask for a HO replacement you will be fine.
MLA
Edited by missinglink
missinglinkaudio
The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
MLA
so ur saying if i get hat 12v alt just ask iraggi for a ho one that does more than 12v and ill be fine? and where can i email iraggi at?
Excessive Amprage
Google it
2 MAW15's
Cadence 1000D
Infinity Reference 6022's
Blankput Tweeters and Infinity 4x6's with tweeters
Powered by a US Acoustic USB4085
1 Rockford 1Farad Caps and a 200 amp ALT
  • Who's Online   0 Members, 0 Anonymous, 378 Guests (See full list)
