Not so regular cab Chevy - Back in business
Looks like fitting all 3 speakers in the door, especially with countersink rings for the grills isnt going to happen.. So i think im going to just mount the two 6.5s in the doors and make some A pillars for the 5.25s.
Posted Image
The 6.5 rings are just tacky looking with the sharp edges and they stick out almost 3/4" so i want to countersink them.
Posted Image
Most likely layout for the doors.
Ive already laid out the door to fit all 3 crossovers, you guys think it would be straight to keep all 3 in the doors for the ease of running power to them and just have the wires run to the A-pillars for the 5.25s with quick disconnects so I can still get the doors off?
Posted Image
Posted Image
looks like a good plan to me and pillars always look cool go for it mang
but i would maybe move around the tweets to take up space since you have so much extra now
edit: or do one 6.5 and one 5.25 in the door for the size differance look
You could put the 5.25 in the kick?
edit: never mind i like the a pillar idea beter
"Audio is not a hobby it's a lifestyle"
_____________________________Refs_1_Refs_2_____________________________
One 6.5 and 5.25 in the door would look better but my dad is kinda sketch about letting me do a pillars because of obstruction of view so Id have to put the 5.25s in the pillars to minimize the size of them..
Alright guys i havent had anything go right ever since i started these doors.. First the dremel overheated on me and wouldnt turn on, got it fixed. Then tonight the router that im BORROWING from a guy that works in the machine shop (just an old craftsman sears) stopped working. I had both 5.25 rings cut and had just done all 4 outer circles for the 6.5s and cut one inner circle, moved to the next one and it wouldnt turn on.. WTF. So i tore it open and the metal tab that the wires quick disconnect to on the switch, one of the tabs actually came out of the non-conductive composite material. Looks like it got extremely hot and just melted the composite material allowing it to slide freely and not make contact with the switch. Going to attempt to rig up another switch and see what happens later. If it works then ill have all my rings cut and mounted tomorrow. Have to figure out how to do the tweeter rings because the hole saws are in a cabinet covered by the immense amount of crap in our garage.
On another note im going to make 3 speakers fit in one door by not flushing the grills and mounting 2 tweets in the fiberglass and leaving 1 in the stock door location.. We'll see how tomorrow goes
Damn you guys i wish id thought of it earlier when i took the router apart but im not a picture taking whore like some people.. Anyway found a toggle switch in my stash that was about the right size and above amperage capacity of the original switch. Was a little more complex than this but basically took the wires, soldered on some ring terminals for the new switch, screwed em on and with some help of the dremel got the switch to fit in there pretty snug. Now the switch for locking the shaft in place to change bits could move freely whenever because originally the slider switch had a cutout that would only allow the lock switch to be engaged when the power switch was off. So i put a spring on the little metal piece that slid in and out of the slot that was on the original switch so it cant accidentally slide while the router is on, but can still be engaged for bit changing. The only other thing was with the new switch there was a tinnnny gap beside it and to keep dust out i simply squirted a bit of silicone in there. Got it all put back together, plugged it in and while holding my breathe flipped the shiny new toggle switch... She came right on good as new :). So ill wake up tomorrow and get my rings finished and hopefully mounted. If all goes as planned i could actually have them wrapped and have the first layer of resin curing by the end of the day but we'll see how lazy i am.
While i was letting the epoxy on the doors set up i decided to fix my amp rack under the seat for the 100.4.
There is a hump at the back of the seat so i had to have the rack angled up in the back to get it far enough under the seat as you can see the RCAs stuck out before.
Posted Image
Before
Posted Image
Posted Image
Posted Image
The reason i had to angle it because before it was too high and the seat slide lever spring scratched my pretty amp :(
Posted Image
No more RCAs under the passengers feet
Posted Image
The bump in the floorboard i had to get the amp above...
Posted Image
So I could easily get to the terminals on the amp
Posted Image
Decided to put up a pic of the fiberglass boot cover so it will stop flexing like crazy. Still have to do the top and then cut it down and cover it with some sort of fabric
Never put up pics of my hinged door i finally put on the console a couple months ago
Posted Image
Posted Image
Finally mounting the rings on the doors
Posted Image
Posted Image
Theyre extremely close just the left 5.25 ring is higher in this pic because apparently i cant take a level picture lol
Posted Image
Nice brand new roll of rockford wire :)
Posted Image
Soldering the quick disconnects for the speaker terminals
Posted Image
Posted Image
Posted Image
Soldered the fork terminals on one set of wires for the crossovers just to see how it would turn out.. I like it :)
Still have to move stuff in the garage to get to the hole saws and cut the tweeter rings, hopefully will get that done tomorrow
