Not so regular cab Chevy - Back in business
looks great. Next time you should also resin up the center of the speaker opening, makes it much easier to cut that circle out when its nice and stiff.
Thanks
Its all good the resin is like atleast 1/2" into the opening so itll be stiff when draggin the knife around the opening.. I see where youre comin from though.
All I had layin around was naugahyde (spelling) vinyl type shit which if youve worked with it doesnt stretch at ALL!
And i suck at wrapping.. so it looks like shit but it sounds pretty fockin awesome.. def noticeably louder and clearer than before.. Makes my ears ring a lil :D
When i order the new speakers and the tweets ill pull these out and re-wrap them with something else better
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>" type="application/x-shockwave-flash" width="425" height="350">
Gonna try to get a good vid during the day tomorrow
Your build looks great, I just read it all! Keep up the good work! Diggin that your playing the no ceilings mixtape by the way, I love it.
DC AUDIO
06' Lancer
Thanks
Just thought this was worth showing..
If you remember my old resting voltage was 12.4..
I have had the D3400s in for 5 days tonight
Every night i have given them a good 15A charge for about 2 hours and then a 2A charge all night just to float them
Also ive been driving a lot since they went in so theyve seen anywhere from 15.1v (Cold start) to 14.4v (warmed up idle) for no less than an hour a day.
This is my new resting voltage :clapping:
DMM on the D3100 in the back
Stinger meter on the D3100
.9 volts increase in resting voltage from simply upgrading batteries...
POWERMASTER FOR THE MOTHERFUCKIN WIN!!!!
This is just 2 hours after taking them off the charger, im not going to charge them tonight and ill check it tomorrow morning to see what my more accurate resting voltage is.
