man i wouldnt do four 10s bc i have the same exact truck but a 1999 model...i use pretty much the same demensions as you do to. i made a box for a single FiBL 12'' sub and the box is about 2.4cuft ported to 32hz. if you want to port those four 10s you are gone have problems with the speakers not fitting due to the port being in the way.....
plus at 6'' in depth for the subs your are not going to be able to flip your middle console up anymore unless you are just going to take it out. and you will need 3/4 thick wood dont use 1/2 thick
http://s299.photobucket.com/albums/mm303/F...dioBuild029.jpg
Edited by FiBTLforlife
2 AQ 10'' HDC3 copper subs
1 3500d AQ amp
146.3db on TL with stock electrical in single cab truck at 32hz
RESULT: 1st place at comp, 3rd overall out of 20 cars
I appreciate the advice. I have made a mold of the floor in the rear of cab, looking to gain airspace. I have also found other subs that don't require as much space in a vented enclosure. Maybe I'll just go back to a sealed design.
... is the box you made for an extended cab or single cab ?
Edited by Alaska_KO
box is for a single cab truck....im getting the woofer today and getting it in my truck and ill have a pic soon....looks big but it just does fit
1 3500d AQ amp
