I plan to put 4 10 inch Fi Audio SSD's in a 2001 standard cab GMC Sierra. The amp I have chosen is a HiFonics BXI 2608D, I chose that one because it is STRAP-able. I need assistance with the box design as I would like to have a vented enclosure. I have seen boxes in which all the subs use the same airspace with only one common port. Is that possible with a behind the seat style enclosure ?
Edited by Alaska_KO
gimme some max dimensions and ill see wut i can do.
i need the absolute biggest the box can be to make sure it fits.
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
I plan to put 4 10 inch Fi Audio SSD's in a 2001 standard cab GMC Sierra. The amp I have chosen is a HiFonics BXI 2608D, I chose that one because it is stackable. I need assistance with the box design as I would like to have a vented enclosure. I have seen boxes in which all the subs use the same airspace with only one common port. Is that possible with a behind the seat style enclosure ?
You mean strapable?
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
55 inches wide, 17 inches high, 4 inch top depth and 10 inch bottom depth. Those are the max outside measurements with the seats in a normal position. If I have to lose some room or make adjustments I can, maybe only use 3 10's . The reason for the 17 inch height is the rear part of the floorpan not flat, so 17 inches is from the highest point of the floor. The box could be taller, the top depth would just need to be less. Thanks for any help
If you account for wood thickness
53.5 wide
15.5 tall
[4+10/2]-wood=5.5
= 2.64 cubes, without acounting for port displacement, speaker displacement, and i dont know the mounting depth of the SSD's, but i'm giessing it will be close. May want to reconsider and use 2 instead
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
53.5 wide
15.5 tall
[4+10/2]-wood=5.5
exactly wut i was about to say.
its just not feasible to run so many subs in such a small airspace.
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
even wit 2 subs the best i can do is .7 cu ft per sub after displacement of subs and port
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
IDK man, 4 10s ported behind the seat of a single cab pickup.
My opinion,
You would probbly be better off useing 2 tens ported.
That would sound alot better than forceing all 4 subs ported with inatiquit(can't spell) air space.
The most I have found is around 5 cubic feet behind the seat. so thats going to be tough.
http://www.ddaudio.com/dd/caraudio/enclosu...lSizeStdCab.asp
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
  • Who's Online   0 Members, 0 Anonymous, 433 Guests (See full list)
