CoolXoc Posted June 28, 2008 Report Posted June 28, 2008 i need your opinion about this amp. its for am 12"sub groundzero uranium 1000wrms ROCKFORD FOSGATE P5002 - http://www.rockfordfosgate.com/products/pr...mp;locale=en_US thank you! Quote
ISO Posted June 28, 2008 Report Posted June 28, 2008 Can the ground zero handle 500 watts at 4 ohm. If so um thats it. LOL Quote Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
CoolXoc Posted June 28, 2008 Author Report Posted June 28, 2008 Can the ground zero handle 500 watts at 4 ohm.If so um thats it. LOL i know its not the perfect amp for my sub..but its an amp that i can buy for a +/- good price, for now... the sub is dvc 4ohm...i know its not the perfect impendance for that amp work.. if i wire in series it will load 1ohm per channel? in bridge mode after i will adquire a good class D with more power. Quote
ISO Posted June 28, 2008 Report Posted June 28, 2008 That amp will not work for you. A DVC 4 ohm sub gives you 8 ohms or 2 ohms. At 8 ohms you will get 250 watts, at 2 ohms your amp will shut off every time the bass hits hard. At 4 ohms the amp will work propperly and give you 500 watts. Quote Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
CoolXoc Posted June 28, 2008 Author Report Posted June 28, 2008 That amp will not work for you.A DVC 4 ohm sub gives you 8 ohms or 2 ohms. At 8 ohms you will get 250 watts, at 2 ohms your amp will shut off every time the bass hits hard. At 4 ohms the amp will work propperly and give you 500 watts. ok, and opinion about the amp..its good? its under or overrated? for an A/B classe its a good amp? Quote
tacomabanga1986 Posted June 28, 2008 Report Posted June 28, 2008 (edited) well ive seen this done befor but cant u wire one coil to one channel and one coil to another, ive done it befor with my old orion 2nt and it worked fine, that will give 250rms each coil @4ohm 2ch, and aint these and the 6002 the really efficent ones that ive seen pics of with like 8 12's and 6 6x9's hooked to it? Edited June 28, 2008 by tacomabanga1986 Quote here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp here's a link to my other system my 90 geo prizm test car heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
ISO Posted June 28, 2008 Report Posted June 28, 2008 (edited) well ive seen this done befor but cant u wire one coil to one channel and one coil to another, ive done it befor with my old orion 2nt and it worked fine, that will give 250rms each coil @4ohm 2ch, and aint these and the 6002 the really efficent ones that ive seen pics of with like 8 12's and 6 6x9's hooked to it? Doing what you said will give him the equivilant of 8 ohm bridged. 250 watts total Edited June 28, 2008 by ISO Quote Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
