Jextel Posted July 3, 2008 Report Posted July 3, 2008 i thought i have blew my subs because the noise i heard sound like they was bottoming out so i pulled over look at the subs and they notice i snapped 3 screws on one sub and 4 was loose on the other subs i replaced and screws and the noise was gone.. Should i use longer screws? and what causes this? http://www.cardomain.com/ride/3042878TEAM DEADLY HERTZ "GET LOUD OR DIE TRYIN"only the loudest will survive.
ISO Posted July 3, 2008 Report Posted July 3, 2008 i thought i have blew my subs because the noise i heard sound like they was bottoming out so i pulled over look at the subs and they notice i snapped 3 screws on one sub and 4 was loose on the other subs i replaced and screws and the noise was gone..Should i use longer screws? and what causes this? Large amounts of vibration is what caused it. I would use a stronger screw, something bigger in diameter. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character.
