have you tried bypassing the 701 and the audiocontrol. run the rcas from the decks sub out directly to the amps.or make sure if you are running the decks ai-net into the 710 then to the amps that the switch under the radio is switched to ai-nit not standard. might be a signal problem not voltage esp if its at 13v and the headlights dont dim.
Edited by jmsonoma03
ya i checked and made sure its a i net i also tryed the bypass of the mvc and still the same thing but i didnt try to bypass the 701 . also i got the reading with the system jus playin reg i didnt try to meter it with it bumping ... to tell the trut i didnt think i would have bin a power problem...
  • Who's Online   1 Member, 0 Anonymous, 1277 Guests (See full list)
