Well I designed this box for 4 12 inch kicker CVRs for the rear on an explorer. I just wanted to get your guys input on the design and make sure everything is right. The box has (2) 4.45622 cf chambers, 2 subs per chamber. Each chamber is tuned to 32 hz with a port slot port 16.375 inches wide by 2 inches in height and 6.43 inches long. So I used a calc to calc out the port and it told me with a slot port that that is the right length so I was just wondering if someone could double check it for me thanks
Edited by Toxiccasper
If you can fit it I would be more inclined to increase the port area and make the port longer to keep the tuning the same.
Also consider bringing the tuning up to more 38-40ish, it'll be a lot louder to the ear and probably better suited to those subs.
10.x volts fo' life!
Thanks but that tuning was right wasnt it? because its different lengths depending if its a slot port or not and I assume that is because it uses the sides of the box for the sides of the port
  • Who's Online   0 Members, 0 Anonymous, 3461 Guests (See full list)
