Needs Help Choosing Subs
Well my girlfriend wants a little bump in her car, so I was thinking just 2 12s, but Im not sure what I should get. I dont want anything that is going to take tons of power because the electrical isnt going to be upgraded so I was thinking like maybe 2 12 inch type Es or 2 12 inch Type Rs depending which would be better for no electrical upgrade. Also the amp cant be too expensive either, but I am open to suggestions.
What kind of space is she gonna give up? will it be ported or sealed? Personally I would go with th typre r's of lvl 2's with a 500-700 rms monoblock. It will not be enough power to get the alpines loud, but will get them moving. depending on budget for the brand of the amp, I prefer power acoustik as far as the "cheap" amps category.
or this
http://cgi.ebay.com/Rockford-Fosgate-Punch...1742.m153.l1262
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
yeah im building ported in the trunk Ill probably go with DC since they have better quality and are better priced, either level 2 or 3 but I dont know if the stock electrical would really like 1200watts for the level 3s?
you dont have to give them full rated power, just make sure it is clean power. I can get you a vid of 2 type r's on 500 watts [in a suv] that gets some good flex.
http://www.stevemeadedesigns.com/board/ind...mp;#entry346016
I would give those lvl 3's at least 300 watts each. Rusty can asnwer your questions about the efficiency of the lvl 3 and which would be right for your application.
Current Setup:
Factory HU with LOC
Amp- sae-1200d
Show Setup:
Subs - 2 RE SE 15's
Box - 5cubes sealed
SECOND SKIN
Ya I have already sent him a message, and this equipment isnt going to be getting pushed hard or anything
What do you think about for a Hifonics Brutus BXi 1206D for the 2 level 3s? and getting the dual 2 ohm for the subs so I could run them at 2 ohm and get about 900watts?
that shoud be good, rusty recommended I get 2 12'' lvl 3's and give them 800rms for the pair, so that should be great.
I doubt you will get 900 watts with stock electrical, but should be enough to push those subs. are you going to port through rear deck? or face forward and seal from the trunk? lots of options depending on the car.
Current Setup:
Factory HU with LOC
Amp- sae-1200d
Show Setup:
Subs - 2 RE SE 15's
Box - 5cubes sealed
SECOND SKIN
just plain ported in the trunk, but yeah Ill probably just get that amp because it would work for either subs, now I just have to find out how much I can spend lol
  • Who's Online   0 Members, 0 Anonymous, 5250 Guests (See full list)
