Got in my Jeep this morning to go to work & started to turn the volume up on the stereo then............ pop.... sounds like its coming from both subs. I can listen to at lower volume. This sh#t sucks :unknw:
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
Can it be my amp or 2 blown subs because i can hear popping in both the subs
MLA module 15+volts
Team Bass Hz
The first thing I will do is pull the subs out.
Do 3 things.
1st smell the subs, stick your nose rite in there around the spider and pole piece.
If it smells real funny or burnt its a bad sine.
2nd put you fingers evenly around the top of the cone and push the cone in and out very gently you may need to put your fingers under the cone and push up on it too.
Listen for any funny sounds, the spider could be poping, the voice coil could be dragging in the pole. A few things could be going on.
3rd use a DMM and check your VCs and make sure they are measureing at the rite ohm load.(This can be done first if you want)
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
If there are any air vents on your amp try and stick your nose in there too and see if it smells funny or burnt.
if everything else is fine next go to your RCAs.
Can you pull your radio out?
If so, pull it out disconnect your RCAs from both the amp and radio, get another set of RCAs and do a straight shot from the radio to the amp and see if the popping stops.
If if stops the RCAs ran through the vehicle have gotten pinched or are grounding out. Replace them and try and figure out were the damaged part is so it doesn't happen again.
Thanks ISO
MLA module 15+volts
Team Bass Hz
Thanks ISO
No problem I hope you find the problem
Hey man get me an update when you can.
I read back through your other thread and I'm hoping its just the amp being to powerful because you should beable to thermal an amp a few times without sustaining any major amount of damage.
Let me know whats up man.
Just had the subs tested & thats not the problem my friend also tested the amp, thats the problem. The first time it gave out on me it was the MOSFETS now what the f*ck, oh well ill just send it back. :angry:
MLA module 15+volts
Team Bass Hz
Do the subs still pop when you remove the RCAs from the sub amp? If so, then it could be your RCAs. If they keep on popping, then maybe you have a poor power or ground connection somewhere.
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
  • Who's Online   0 Members, 0 Anonymous, 2765 Guests (See full list)
