These are great SQ sub cones, Ive used them many times. They are a slight undersized on surround mounting, so they are more meant for stamped steel frames, or PA style alum frames
The 10" has a 2" VC opening, and about 1 good easy 1.25"-1.5" xmax ability
These are REAL carbon fiber, they do conduct electricty, so you would need to shring wrap the tinsel leads
The 12" have a 2.5" voice coil opening, all the same specs both operate best with about 25-35hz fs
The rubber surrounds are easily removed with a little bit of heat, so you can use the surround for other cones, or use different surrounds on the carbon fiber cones...
I also have about 25 aluminum domes that work with these cones perfectly....
These items are for the die hard speaker tinker'er, or even a small company that wants to do a run of carbon fiber subs at a budget
I have 200+ carbon fiber 12" cones
and about 25- 10" cones
I want to sell these for about $7.50 each for each 12" cone
or $5 for the 10" cones
1 box of 100 (2 boxes and some extras avail) 12" cones for $250 OBO
all 12" CF cones for $350
Alum domes $5 each, these are spun aluminum, high quality, light thick, and durable
Megalomaniac has a few he bought from me :db:
and used them on his SI 12"
If you were to buy these from a factory, factory direct they would be well in the $15-20 each range, not to mention you would HAVE to buy a min of 100 to even 1000 pieces
heres some pics
these pics are a lil old, but they are the same
BTW, the VC openings CAN be cut to accomodate larger coils, like this one for a 3" coil
This topic is now closed to further replies.
