KICKERKX1200 Posted July 15, 2008 Report Posted July 15, 2008 i am installing a kenwood dnx8120 in a ford edge. i am also installing a PAC swi-jack for the steering wheel controls. in the directions it says to cut jumper and put in a 100ohm resistor from purple wire to white wire. the question is this, the kit does not have a 100ohm resistor only ones close is a 47ohm and 150ohm so which one do i use. thanks
jmsonoma03 Posted July 15, 2008 Report Posted July 15, 2008 if it didnt come with one go to radio shack and buy one.
Ray Posted July 15, 2008 Report Posted July 15, 2008 you can the both of those together 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
jmsonoma03 Posted July 15, 2008 Report Posted July 15, 2008 if the instructions say 100ohm it should come with one but you can try them but i dont think they wold work a tolerance is a little above or below might work but it has to be close to 100ohm.
Ray Posted July 15, 2008 Report Posted July 15, 2008 you should get 102 if you parrallel them 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
jmsonoma03 Posted July 15, 2008 Report Posted July 15, 2008 there you go rays the man its been a long time since ive done one but the ones ive done never needed resistors. good luck
Ray Posted July 15, 2008 Report Posted July 15, 2008 only gotta be within 10 percent 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
KICKERKX1200 Posted July 15, 2008 Author Report Posted July 15, 2008 thanks ray that worked. unit is all in and very impressed so far
