bigal333 Posted December 20, 2006 Report Posted December 20, 2006 Just got my AudioControl Three.1. :w00t: Can anyone tell me what the gain on top of the eq should be set at? half way, less than half way, more than etc... If I'm correct, this does have Master SUBWOOFER volume control right? It's one of the features that most caught my attention.
dmanson Posted December 21, 2006 Report Posted December 21, 2006 Just got my AudioControl Three.1. :w00t: Can anyone tell me what the gain on top of the eq should be set at? half way, less than half way, more than etc... If I'm correct, this does have Master SUBWOOFER volume control right? It's one of the features that most caught my attention. yes it has a master control for the subs. just make sure your sub output for the RCA's on the 3.1 are running to the sub amp(s). as for the left and right gain setting ....... make sure the left and right gains are at minimum and then you need to cut your Headunit about 3/4 of the way up (as said in the manual), then slowly turn your gains(left and right) up. you'll see the little light next to the gains start to blink. be sure to have a nice consistent CD with good bass as the light will blink with the bass. when the light blinks constantly, back down on the gains a lil and you should be set. on my 3.1 i don't even have the gains near 1/4 of the way up and it's loud as hell. good luck. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
